I'm cleaning out the garage and selling off stuff that I aint gonna use. Lets get the show rolling.
DIS-4 plus ignition box w/ dis harness adapter $175 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0476.jpg)
B&M short shifter for 4th gen F-body $75 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0478.jpg)
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0477.jpg)
Greddy ProfecII boost controller w/ cheapie boost gauge $85 +s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0475.jpg)
Cloyes double roller timing chain for older iron head 2.8l and 3.4l $50 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0466.jpg)
3400 adapter rocker studs for use with aftermarket roller rockers $40 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0465.jpg)
Some "Iron Head" ARP head studs w/out washers and some slight surface rust $35 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0464.jpg)
Sollid roller lifters. (good for 9000+ rpms!) $150 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0463.jpg)
Old turbo piping from my old system. I used it on both a 3400 and 3.4l iron head motor. When I built it, I didnt weld in a flex-pipe in the merge pipe so you may want to chop and modify it some. It wont fit stock accessory brackets and again will need some modification to fit. It would be a good system to modify for some other 60 motors (accept the 3500. ports are a bit small). Im selling it cheap... $175, including the wastegate. The only catch is that I WONT part it out. Its all got to go. Its taking up space and I want it gone.
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0457.jpg)
![](http://i141.photobucket.com/albums/r48/Driver_10/th_IMG_0461.jpg)
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0460.jpg)
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0459.jpg)
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0458.jpg)
And finally this "goofy looking" camaro high-rise wing as advertised by non-threatening black guy in the picture $5 + s/h
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0473.jpg?t=1318180225)
![](http://i141.photobucket.com/albums/r48/Driver_10/IMG_0472.jpg)
