I have 1 of only about 18 Eaton M62 superchargers for the N-Body. This is the only M62 whose outer case has been polished. The charger had an overhaul about 2,000 miles ago. Had bearings replaced and it was ported and polished. Comes with
-Eaton M62 supercharger
-Intake tubing
-K&N filter
-LS1 MAF
-Billet 65mm TB
-EGR delete
-Hardware to install
Asking $4,000 firm.
Wot-Tech ported and polished 3400 UIM with top grounded smooth. Ported for 65mm TB Brand new never used. I can paint it or polish the outside if wanted. $175
Wot-Tech ported and polished 3500 LIM new never used. $120
Billet N-Body engine mount, with poly bushings (RED) $180
I only have the one on the left, with the red bushings.
Wot-tech Race Camshaft, brand new never used. specs can be found here. $280
4T65E HD transmission, this is the tranny out of the GXP concept car, ready for a 3400 or a 3500. Has axles, new tranny filter, and poly mounts. Only few hundred miles put on it since the rebuild, and gears have been converted to 3.29. $1,700
-Intake tubing
-K&N filter
-LS1 MAF
-Billet 65mm TB
-EGR delete
Asking $4,000 firm.
