LX9 Oil flter base as pictured
  • LX9 Oil flter base as pictured
    Looking for the oil filter base like this. I don't know what vehicles it was found on. I didn't get one with my Uplander engine, filter screws into the block.
    I have one that I won't be using, PM Sent.
    2000 Grand Am GT
    2011 Chevy Impala
      Also have one if above falls through.
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
        can these be used on a 3400 fwd to remote mount your filter, i should have asked cncguy but it wont let me delete the post sorry
          Remote mount where?
          Without it the filter seals up against the block and sits angled. With it, it sits in the upright position and futher down. Might not clear the subframe in some cars.
          1994 Corvette
          LT1/ZF6
          3.7/42RLE
            PM'd
              The oil filter adapter from a newer engine uses three bolts to attach it to the block and will not work on the older engines since they don't have the mounting holes. However, you can use a filter adapter from an earlier Beretta, Cavalier, etc as they mount using a single hollow bolt through the center. The threaded nipple that mounts the oil filter has a 10mm internal hex. Just use an allen wrench to remove the nipple and the old style adapter goes in it's place.
              MinusOne - 3100 - 4T60E
              '79 MGB - LZ9 - T5
              http://www.tcemotorsports.com
                CNC I think it might be a little bit more complicated than that. I don't have my old block anymore to confirm but at a minimum I believe the thread size for the filter nipple in the block is different on the 3900 compared to the previous. At least on the adaptor it is as I had trouble getting the standard size oil filter bypass fitted in place of the oil filter and suspect they used the same size in the block.
                My uplander engine came with a sandwhich style oil cooler fitted between the filter and the mount and I don't believe any of the stock Uplander engines came with a direct block to oil filter connection unless they changed over the years.
                  http://www.fiero.nl/forum/Forum2/HTML/084972.html
                  Joseph,
                  My 2006 uplander LX9 did not come with an oil filter adapter as seen the the enclosed picture.
                    Very strange. I've had quite a few '04~06 LX9s here which all had the same threads as the older engines and I am using a Beretta adapter on my '06 LZ9. What year is your 3900?
                    '79 MGB - LZ9 - T5
