Well, this is the best picture I could find. That isn't the power steering pump that I'm currently using. The picture shows a 3.1mpfi pump that I used for mock-up. But you get the idea.
You're running it like that? Not much belt contact on the water pump.
'98 Volvo V90 - Ford 5.0 swap in progress '96 LR Range Rover 4.6 HSE - suspiciously reliable '92 Volvo 740 Wagon - former parts car, now daily-driver beater '71 Opel Kadett Wagon - 1.9L CIH w/ Weber DGV 32/36, in bits
We don't have any good junkyards here. Small town. The big u-pulls are more than an hour away, I've never actually been to one.
Want to make a few extra $?
I'm not as far north as you, but we still have the white stuff on the ground
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
Good to know. So that's the 3400 timing cover? My tensioner is in a different place and applies pressure towards the outside, clockwise.
This is my actual engine:
Yup 3400 timing cover, And what are you putting this in? You can move the tensioner to to location that it supposed to be in on the timing cover like the previous pic
Yeah, I just pulled my water pump/timing cover out of the box and saw that foam-backed plate and the alternative tensioner mount underneath. So all I really need is the alternator and the power steering pump.
I'd LIKE to get my A/C reinstalled, but it's only worked two months in the last nine years, so not THAT big a deal... I just don't see how an A/C compressor can co-exist with my motor mount using this FWD cover.
Worked on the engine some more this evening. The LIM will need to be turned. That means no PS pump, which means I can't use the 3x00 brackets, and therefore I don't need any of the parts I requested. :/
Off to the salvage yards to find a RWD setup!
