Looking for some ideas from you guys..
My 1990 TGP has been my daily driver for the past 8 years. In that time I did a big turbo upgrade project, to a $1200 GT2871R turbo (475 HP-capable) with all custom braided AN hoses and fittings.
The car is now at 209K miles and rusting and clearcoat cracking. I really took care of it and maintained it well for the past 8 years but Wisconsin winters take their toll, as does the mileage.
I also:
- upgraded to 30# GMC Syclone fuel injectors, then...
- realtime laptop tuned the chip extensively myself (years & hundreds of changes) with Wideband O2 sensor and Moates Ostrich emulator for maximum safe power at 14 PSI boost on 93 pump gas (350 HP)
- JeffM Crossover pipe
- installed LS1 valve springs
- had the 4T60 professionally rebuilt by Roadmaster Transmission in Chicago to the best parts available around 130,000 miles
Since the transmission was rebuilt I've put on 80,000 miles and now it has 209,000 miles.
THE BAD:
Problem is I live in Wisconsin and drove it in winter so the underbody has a lot of rust & corrosion:
Now fuel tank sprung a leak last month and when I put it on a lift, I saw the control arm mounts are also corroded and decided it would be best not to drive it anymore.
The headliner also is falling down because the sunroof had a small leak that I could not solve (even after much effort). Now the sunroof (which did still work) has been caulked shut.
The transmission is also due for a rebuild, it works fine but after 80,000 miles since last rebuild, it no longer can handle full power (350HP) WOT shifts. It is fine for daily driving and has an awesome shift kit installed from the builder.
So my question is, how do I sell this and get the most money out of it? I need to sell this and buy another daily driver, and I don't have a lot of time. I am not a mechanic either (although I did the turbo install all myself). So I am not looking to part it out and spend weeks disassembling it into little pieces and shipping tons of little packages out.
THE QUESTIONS
Do I sell it as is? Maybe to someone looking to transplant the powertrain to their own 60v6 project?
Do I try to sell the GT2871R + 30# injectors + chip as a separate combo for someone to basically bolt-on upgrade their TGP to a 350HP big turbo tune?
I have about ~$1700 into the:
- Garrett-rated dual ball bearing 475HP GT2871R Turbo
- Moates Ostrich chip emulator
- 30# GMC Syclone injectors
- custom braided AN hoses and fittings and adapters for oil + coolant
- stock downpipe modification to fit WBO2 sensor
If I do that, what do I do with the car? Is it worth reinstalling the stock turbo and stock injector? Remember I'm not a great mechanic so it takes a HUGE amount of time and effort for me to swap turbos. I'm not like you guys who can bang it out in 2 hours time.
With the car high mileage and rusted, am I looking at junking it? I hate to see a 1990 Turbo Grand Prix suffer that fate, especially when it seems like it still has a lot of good parts.
Thanks for your advice guys.
I also:
THE BAD:
THE QUESTIONS
