$125 65mm TCE assembled and ready to install with the sensors + shipping. or OBO
65mm TB
65mm TB
Last edited by ShieldsM; 09-14-2010, 06:24 AM.Stage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so onTags: None
I have 3 that is my problem. My wife wants spare parts to start to goStage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
SOLDStage 2 Comp WOT-TECH heads, upper and lower intake P&P, street/strip cam, Custom pushrods, TCE LS Lifter Springs, Dimond Pistons 10.7:1, 65mm TB, stage 3 custom cold air intake, heat shield(only for Heat protection on Temp and MAF sensor), DHP Tuner, Adj FPR, #28 injectors, MSD ign coils, talyor wires, S&S header, S&S high flow cat, borla cat Back, all ARP studs, TCE double timing chain with crank kits, Cometic head gaskets, A/C deleted, HF water pump, and so on
