Or whatever's similar to 17109826. I just need to keep the car running while I get one set or the other cleaned. I prefer the pre-2000 style connector (Bosch?).
#19 Injectors
I've got set's from a couple L67's (SI and II),Fiero,TGP,LS1,and various Ford injector's.
I'll check for you and see if I have any of that part number and what style plug it has.
Pretty sure the TGP and Fiero are 17 or 19lb.
I'll take $35 shipped for the TGP and Fiero injector's as is.
If you want them sonic/pressure cleaned with my injector flush machine I can do $65 for the set shipped.
Originally posted by flimbobI've got a set of 25322180 Multec 2 injectors from a 00+ Malibu. $40 + shipping
Originally posted by DefEddieI've got set's from a couple L67's (SI and II),Fiero,TGP,LS1,and various Ford injector's.
If you want them sonic/pressure cleaned with my injector flush machine I can do $65 for the set shipped.Last edited by Azrael; 05-05-2010, 11:05 AM.1995 Grand Am SE
ill have to look through my box of injectors by im fairly certain i have a set of 19# injectors.
wont get down there till friday to look. let me know if that's good.sigpic
99 Grand Am GT
Originally posted by Azrael View PostThanks for the offer, but I think those use a different connector.-60v6's 2nd Jon M.
True dat... Can't say I blame you any there, really-60v6's 2nd Jon M.
I have a set of 90 model TGP injectors that are 19lb and should be same plug.
They are actually mounted in the flush machine now,not cleaned but I have checked spray pattern and leakdown on 3 of them.
Part number is 17086981 if you want to double check the cross reference.
I can post a pic for reference if needed.
