Stock 3.1/3.4 Valvespring retainers
  • Wanted Stock 3.1/3.4 Valvespring retainers
    I need 16 stock valve spring retainers off a 3.1/3.4 pushrod engine. Need to be from the 2nd gen motors unless the first gen retainers are the same.
    let me know what you have
    Got some from a 1999 3400 if you want them.
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
      bump still looking
