Anyone have some for a 3400?
Crank & Connecting Rods
1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut BracesTags: None
How would I polish it? And how much would you want for it?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
You take it to a machine shop and have them polish it.-60v6's 2nd Jon M.
How much would you want for it?1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
From his FS thread...
Originally posted by 92cavquest View PostCavalier
95-99 cavalier brake calipers w/ hardware and semi-metallic pads $25
95-05 cavalier 4t40e trans mount $10
95-99 cavalier 3 speed trans mount $10
95-99 cavalier 2.2 ohv front motor mount $10
95-99 cavalier 2.2 ohv alternator $20
95-02 cavalier radiator cover $5
95-99 cavalier gauge cluster w/o tach $10
95-99 cavalier 3 speed shifter assembly $10
Grand Am
4t45e side cover $10
3400
3400 front timing cover w/ water pump $15
3400 oil pan $25
.10 over crank bearings $25
3400 windage tray $15
3400 crank (polished and checked by machine shop)$40
3400 pistons and connecting rods $45
3400 block -hot tanked,honed, glyptal coated and machined oil passages, new cam bearings (prefer local pickup) $120
3500
3500 upper intake $70
36# GTP injectors w/ pigtails $75
3500 fuel injectors w/ harness $40
3500 fuel rail $25
3500 exhaust manifolds w/cats $40
WOT-TECH stage 3 turbo cam 1617 grind $250
custom pushrods for the cam above $100
misc. other 3500 junk (let me know what you need)-Brad-
601341999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
there is a guy selling a forged 3500 crank on the alero forums if you dont end up buying this one, i dont know what modification you would have to do to get it to fit but it can be done i think.2002 Pontiac Grand AM GT K&N WAI, Pacesetter 2.5' piping/SLP loudmouth exhaust, Magnaflow High Flo Cat
2006 Pontiac GTO 6.0/Iron 370, Kooks 1 7/8 Longtube headers, Mahle forged pistons, Scat H-beam forged rods, Custom Cammotion boost cam, Magnaflow Catback exhaust.
Coming soon: Trickflow 235 heads & Magnacharger TVS 2300
