$4500 OBO
Up for sale is my 94 Convertible 82k Miles, LOADED, everything original
I love this car, but I have to sell it, we are having a baby girl in January, and I need to get rid of some things and above all, get some extra money.
This is a loaded car I have been hoping to get around to restoring a bit, drivetrain is great, starts easy, accelerates incredibly quickly and corners great. I am using Mobil1 Oil and changed the Transmission fluid to Mobil1 Syn.
3.4L DOHC engine and 4speed Auto w/ OD
Black paint with the sawtooth rims,
Black interior with the Dark Graphite Leather.
HUD - Heads up Display (you get the speed, blinkers warning lights projected on your windshield
Convertible top works very nicely and pretty much everything is original.
Factory Lip Spoiler
Fog Lights
I bought this back in 2005 or 2006 from California and drove it home.
Things I have fixed on it since I owned it.
Blinker switch - he had rigged it up with a 3 way toggle, i removed it and replaced the switch and wiring
Convertible top - fixed leak and now goes up and down
HUD - replaced switch that was broken
Ashtray/Center trim - replaced missing ashtray and piece of missing trim
Trunk Lid - plugged hole in trunk
Alignment - was wearing tires on inside
Replaced Battery
Issues I can find:
A/C - leaks out R-134a in about 3 or 4 days, but compressor runs and cools very cold when added.
Drivers door is hanging down a bit, bottom of plastic is worn and bottom trim is off, window controls have fallen in a bit and drivers window button is missing, windows all work except rear left
There are several minor things, the power antenna isn't working, there are various scratches but the only significant ones are on the trunk lid. The previous owner had cut a 3/8" hole and had a big antenna. I have a plug in the hole but you still see the wear marks and some scratches on the trunk. The jack doesn't work, water got into the spare tire. There are a couple of tiny screw holes in the center of the dash and 3 on the passenger side hump near the shifter and a bit of foam under the am/fm/eq/tape deck where the previous owner had a bunch of electronics installed. Tires have some wear where they were wearing the outside edge because of a bad alignment. There is an evap gasket that needs to be installed that only lets you go to a bit below the yellow warning line rather than the red E line on gas. Small hole on drivers side leather seats. Low Coolant warning light comes on, even though the coolant isn't low.
PM me if you have questions
Factory Lip Spoiler
Fog Lights
Replaced Battery
Issues I can find:
