Performance Camshaft
  • For Sale : Performance Camshaft
    Selling my camshaft due to the fact that it is a little too much for my build; not that great for a daily driver. I bought it used, it has less than 100 miles on it. Don't know much about it other than its 540/520 int/exh lift 232/240 int/exh duration at 0.050. It could be polished up a little bit as there is some surface rust, but its fine the way it is.
    Really all I want is what I paid, $185 obo + shipping. Actually, really all I want is this gone. Once I get it back from Ben, I will be able to ship it.
    1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
    Is it a regrind, a grind from a blank, or OEM hollow core regrind? I'm sure that will determine who wants to buy it.
    Where did you originally get the cam from if you sent it to Ben? I'm assuming he has it to profile it and provide the grind?
      I honestly don't know anything about this cam other than what I posted. I know it fits the 3400 engine and 540/520 int/exh lift 232/240 int/exh duration at 0.050. I got it from a guy on gaoc who used it in his car for about 100 miles.
        found you post and heres the .050 duration
        99 Grand Am GT
        1357 cam 227 233 .050 dur
        515 515 lift 112 lsa
          Ok that duration looks a little more more down to earth! LOL
          Still a pretty healthy cam. Would make some good powwah!
            i found the post from the guy he bought it off of on gaoc.com. thats all the guy gave for specs.
            send the guy you bought the cam from a PM on gaoc and see where he got it from.
            99 Grand Am GT
              He doesnt really reply to my PM's anymore after I asked if I could return it.
                just ask him where he got it. dont even mention anything about returning it in the subject line so then maybe he will look at the PM.
                99 Grand Am GT
                  Damn thats a nice cam :/ too bad im not working on the GA anymore
                  2002 Pontiac Grand AM GT K&N WAI, Pacesetter 2.5' piping/SLP loudmouth exhaust, Magnaflow High Flo Cat
                  2006 Pontiac GTO 6.0/Iron 370, Kooks 1 7/8 Longtube headers, Mahle forged pistons, Scat H-beam forged rods, Custom Cammotion boost cam, Magnaflow Catback exhaust.
                  Coming soon: Trickflow 235 heads & Magnacharger TVS 2300
                    Don't forget the 2 pin setup. You will need to modify a cam gear to use this cam.
                    This is a hollow tube 03+ cam with very little base lobe left. There is also some surface rust and scratches so polishing is going to be required.
                    The lobes were welded and ground and this is most likely not a street oriented cam. Possible, but it takes quite a spring to control it I am sure.
                      goddamn, that's a hell of a profile...
                        Lift rule cam. It will require a high spring rate and wouldn't suggest using SI valves with it.
                        anybody planning on a nice N/A build should jump on this and rape the competition
                          This cam would go great with my Manley Racing valves sorry about the thread jack
                            would it come with or where can anyone get the pushrods for this??? ben do you make them for this cam
                              Yes, he sent me the cam to spec for pushrods so I can get those made.
