I just bought a this car and got it home and started having various electrical/wiring problems. Apparently someone removed engine/trans without properly disconnecting everything. Pretty much everything was cut, then but-spliced later. I have had to re-run wires from the ecm to make stuff work but I am still dealing with a lot of intermittant stuff. I may be interested in an ECM +ecm mounts too, I am sure this wiring mess hasn't treated it nicely.
91 GTP 3.4l 5 speed engine wiring harness
Your best bet is probably going to be a you pull it yard, and since your town is close to Indy, you shouldn't have too much of a problem finding one.-60v6's 2nd Jon M.
It would be cheaper that way too. Otherwise, the wreckers would charge a quite a bit for the whole harness....1991 Grand Prix STE
3.4 DOHC
1 of 792 Produced
Extensive Mods Done
1991 Lumina Z34
3.4 DOHC
Getrag 284 5spd
1 of 30
I have hit a few yards and there are a few 3.4l GTP's out there, but I have been limiting my search to the ones with manual transmissions, as rare as they are I have had no luck. Could I pull one with an automatic trans and somehow mod it to work with my man trans? I am not sure if anything even connects to the man trans...1992 Grand Prix SE 3.1l 155k SOLD
1992 Grand Prix GTP 3.4l 55K
1991 Grand Prix GTP 3.4l 5 speed 99K SOLD
1988 Pontiac Fiero GT 2.8 5 speed Turbo 36K Sold
2011 Mazda 3s 5dr 6 speed
2008 Grand Prix GXP 5.3l 24K sold
Yes you can. My 92 was originally an auto car and I put a 5 speed in its place because I got tired of changing transmissions. The VSS wire is on the passenger side on the auto. The harness needs to have the snake-skin removed and move the sensor plug to the drivers side. IIRC, the VSS plug on the manual is the same as the auto. Also, the purple and yellow wires on the P-N safety switch need soldered together (those are for the starter). There are also two other wires in there (Orange and Light Green), those solder to the pigtail you will cut off of your 5 speed harness for your reverse lights- polarity on it really doesn't matter. Also connect the Green/Black wire to the Orange wire so your trunk popper works (it hooks into the P/N switch so you can't pop your trunk while going down the highway on accident).Also the Tan/Black wire from the transmission control plug needs to run to your shift light (or B-7 on the White plug on the ECM) which is something I didn't do.Last edited by pocket-rocket; 09-23-2009, 02:45 PM.-60v6's 2nd Jon M.
i hate to even chime in on this.. I also hate to get your hopes up.. I have a complete engine harness for a 92 Z34 5-speed.. Which BTW is the same as you need.. Bad part is i have it pretty much sold...Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built car
Originally posted by 94GPGTP View Posti hate to even chime in on this.. I also hate to get your hopes up.. I have a complete engine harness for a 92 Z34 5-speed.. Which BTW is the same as you need.. Bad part is i have it pretty much sold...
Well if they back out let me know I would be quite interested!! This project will prob wait a few weeks/months anyway. I need to do the top end (-heads) and trace down my OPSU wires for now.1992 Grand Prix SE 3.1l 155k SOLD
That's ok, he got a lot of peoples hopes up in this thread as well...
Why he would post this if it is "pretty much sold" is beyond me...-60v6's 2nd Jon M.
Well, thanks for the lengthy write up on the auto to manual conversion for the harness, pocket rocket. I will probably end up going that route in a few weeks.1992 Grand Prix SE 3.1l 155k SOLD
Not a problem. Luckily I found my Helms manual so I was able to figure wire colors, lol. Otherwise the only thing I would have been able to say as far as wires go is hook the big two together or your starter won't work, lol. BTW, if you don't have a Helms manual and you plan on keeping the car a while, you should check on ebay for them. They are the same manuals the stealerships use.
Here you go $30 and some change:
Originally posted by pocket-rocket View PostNot a problem. Luckily I found my Helms manual so I was able to figure wire colors, lol. Otherwise the only thing I would have been able to say as far as wires go is hook the big two together or your starter won't work, lol. BTW, if you don't have a Helms manual and you plan on keeping the car a while, you should check on ebay for them. They are the same manuals the stealerships use.
http://cgi.ebay.com/ebaymotors/1992-...=p4506.c0.m2451992 Grand Prix SE 3.1l 155k SOLD
The only thing that would have changed would be things that wouldn't have an impact on any function of the car. I found some discrepancies between my 91 and my 92. Things like the shape of the seat back on the front seats (full width gramma style in the 91, sporty narrowed at the top in the 92), the gray stripe that goes around the outside of the car (solid gray on the 91, has a red line around the bottom of the 92), stuff like that. Anything to do with chassis, wiring, mechanics and function will all be the same, so I would save your dough unless you really want to spend it since you already have the good manuals.-60v6's 2nd Jon M.
Found you a harness. It's from a 92 gp I believe. But all harnesses are the same. He is a member on w-body. He told me to give you his cell number and call him up. The harness is ready to ship outto you.
419-376-4073 name is Alex.
I hope you grab this from him. Lmk the outcome.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
I joined this forum just to find this thread, Im Alex as seen in the above post... I do have the harness complete with the C100, have PCM to go with it if you need it... I have TONS of spare parts in my shed that I need to sell so I can throw some more things in the box to you if you would like, Ill be making a thread soonAlex (Big Al) Walker
someday GM will pull its collective heads out of their collective asses and listen to us... or go bankru... oops.
