Looking for a stock 3.1 Cam
  • Looking for a stock 3.1 Cam
    I'm looking for a stock 3.1 cam. Its out of a 96 Pointiac. The old one is broke in half. Thanks...Gerald
    i have 2 cores.. one is a solid cam and one is hallow..butas youare needing a good one im no help..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
      Whats the issue with the solid cam. Is it rusted or brokn??
        worn lobes..
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
          I don't have a cam but be sure to check your cam bearings before installing the cam.
          MinusOne - 3100 - 4T60E
          '79 MGB - LZ9 - T5
          http://www.tcemotorsports.com
            My thinking on the block is to send it in for a hot tank job with new cam bearings and freeze plugs. I did a quick check on the cylilnder walls and crank journals and they look ok for a rebuild. Is there anything else that I should have the machine shop do while I have the block into them?
              typically if you broke a cam in the block there is going to be other issues, In my opinion it would probably be cheaper to pick up a used running engine from the yard and drop that in. You could even upgrade to a 3400.
                ^^^Rebuilding a 3.1 after that type of failure is, in and of itself, a failure!!
                Lots of good engines
