3400 engine parts
  • For Sale : 3400 engine parts
    3400 heads with valve springs and valves: 75 plus shipping
    2 oil pans, one for n bodies with level sensor and one without: 25 each plus shipping.
    2 timing covers with water pumps: 20 each plus shipping
    3400 exhaust manifolds with crossover: 15 plus shipping
    3400 crank with flexplate, needs to be tapped, the snout for the harmonic balancer bolt is stripped: 15 plus shipping
    3400 camshaft: 25 plus shipping
    3400 lifters: 15 plus shipping
    3400 pushrods: 10 plus shipping
    3400 oil pick up and drive gear shaft: 15 plus shipping
    3400 block(needs to be cleaned): 40 plus shipping
    ARP rod bolts(brand new in package): 50 plus shipping
    MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
    ill take the intake manifolds
      edited for new prices and a new product at the bottom.
        added ARP rod bolts
          to the top
            ttt with new prices
              the heads aluminum or iron?
                aluminum
                1999 Grand Am SC/T - 301HP, 365TQ - ARP Rod Bolts, ARP Oil Pan Bolts, ARP Head Studs, Mild Cam, 3500 Heads w/28696 Springs, Ported 3500 LIM & 3400 UIM, GT32R @ 12PSI, Rebuilt Trans, 42.5 Injectors, Racetronix Fuel Pump, TCE Adjustable FPR, SC/T Kit, SC/T Spoiler, Shaved Trunk, WOT-Tech Coil Overs, Solid Rear Laterals w/Poly Bushings, Control Arms w/Poly Bushings, Poly Engine & Trans Mounts, Front & Rear Strut Braces
                  Where are you located?
                    illinois
