For sale, 2 used Magnaflow Chambered Mufflers. These are aluminized steel. Like the topic title says, they are 2.5" in/out.
They were on my car for about 1.5 years and less than 5k miles. As you can see in the pics, no rust to speak of other than some very light surface rust on the weld seems. Never winter driven.
They have welded to them hangers for the stock mounts at the rear of a 91 GP. The muffler tip end is cut clean. The inlet end is cut with some pipe still welded in. I can cut it past the weld if you really want, I was just too lazy at the time. There is plenty of 'lead' pipe going in/out. You may want to replace the hangers as those are a bit rusty. They aren't bad or about to break but they look ugly if you care about that.
These are chambered muffs, fairly loud, comparable to a Flowmaster 40 series which I had before these. I think these sound a bit better than the FM 40s and they don't resonate inside the car nearly as much as the Flows.
I went to a 1 muffler setup and don't need these anymore.
$50 takes the pair. Not sure what shipping is but let me know your zip and I can get a quote in a day or two.
The pics:
the $10 bill on there is to give you an idea of the size of the mufflers.
outlet side with hangers
inlet side, with a bit of pipe welded in - I can cut this off if you want so its a clean inlet
The pics:
