Garrett T3 .48 Exhaust housing
  • Wanted Garrett T3 .48 Exhaust housing
    I am in need of a Garrett T3 .48 A/R 5 bolt exhaust housing that is the standard Garrett part (not the mopar type).
    Diff ratios may work I'm not sure.
    I dont know a whole lot about turbo internals, I have a stock T3 from a 2.2 Mopar, I just need a housing that the regular Garrett wastegate assembly will fit (standard 5 bolt garrett wastegate wont fit the mopar style T3).
    Let me know if you may have one that will work. Thanks
    dbl post
    #1 1989 RS - THE L98 AND LT1/LS1 KILLER
    1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) 28 PSI, TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
    #2 95 granprix 3100 all stock for now
    ported heads and cam comming soon, megasquirt ems and turbo down the road
      i have one but its attached to a t3 50 trim turbo lol
      worth it to buy the whole assembly?
        I'm trying to find just the housing since I dont have much to spend.
        But if its a runnable turbo, and the price is right... well you know how it works.
        It must be made for the standard 5 bolt wastegate assembly, I baught a special 5 bolt V-band adapter and the stuff to make it work only to find out it wouldn't fit my (mopar) turbo.
        This is what it must fit, the bolts measure 3 5/8" center to center across, and 5" from the bottom hole to the top left hole (as pictured).
          it has a 5 bolt flange but i think there are 2 diff 5 bolt flanges???
          slight lil crack on the edge of the wastegate hole but thats common and it would go away if u ported it.
          i had 2 of these but one was no good and i threw it out like an idiot
          ill get a picture of the hotside for u tommorow so u can make sure its the right one
          turbo can be bolted on and run
          had a guy who does gn turbos check it out for me
          turbo is water and oil cooled
            just saw ur picture pretty sure thats it.i will take apic and dbl check for ya tom
              i brought the turbo home with me from work soon as i find somethign to mesure the bolt spacing with ill let ya know if its the right one
                just measured
                i got 3 5/8 across the turbine wheel center to center
                and 5 inch across center to center
                  Awsome, send me a PM and let me know what you want for it. If I dont get it my buddy offered me a brand new XS Power T04E for $150.00 but i'll have to fab up a wastegate on it.
                    pm sent
                      I have one but its a .63ar. Might be better suited for you then the 48 i would think. PM me and Ill work a deal with you
                      Best 1/4mile ET - 12.9
                      Best 1/4mile MPH - 111
                      1997 Ford Ranger Splash
                      Daily Driver
