I have a set of 1.6 stamped rockers forsale. You might ask, "Why would I want those?" .
If you have a 2.8 or 3.1 mpfi and your engine has the stock rockers, you'll find that the rockers in there now are 1.5 ratio.
What these 1.6 rockers are made to do, is to mimic as if you installed a slightly more aggressive cam. What's great is that you will not have to pull the engine, heads and all that jazz to install these.
If you can replace valve cover gaskets, you can install these.
You reuse your pushrods, studs, guides, bearings and nuts. Just replace the old 1.5 rockers with these 1.6's!
No tune is required, no extra fuel is needed, and it's an easy modification!
50.00 SHIPPED anywhere in the USA ( OBO )
Will ship to canada, PM for shipping quote.
