I have no use for this stuff anymore and I am more or less just trying to get rid of some of the clutter.
All items as pictured, in other words, what you see is what you get.
If you would like a larger or different pic let me know. Prices do not include shipping (I am in CT).
3.4 DOHC K&N Drop in filter for stock airbox (guaranteed fits 1991 airbox, maybe others). This is a used but excellent condition item. Could use cleaning/oiling. No defects. $6
3.4 DOHC front and rear motor mounts. Used. About 40k on these but they feel solid. These were dealership installed so they are OEM. From a 1991 5 speed car. $20 for both (sorry about the chopped pic)
3.4 DOHC car Steering Rack. Used. This is a rebuilt unit that has less than 5,000 miles on it. 3 turns lock to lock. Comes with pressure sensor. Does not include tie rod ends. Guaranteed to fit 1991 models, likely fits others. This is like brand new. $35
W-body sunroof deflector. Pulled from a Buick Regal. $5
3.4 DOHC Injector Harness. I believe this is from a 97 Monte Carlo 3.4DOHC. Includes charcoal canister and some other kind of valve as well as harnesses for other sensors. $8
Gen II 3.1 Throttle Body. Needs new gasket for IAC cover. Sensors not included. $8
Gen II 3.1L Fuel Injectors. $5
Gen II 3.L New Felpro Valve Cover Gaskets. $4
Heater Core. From 1990 Beretta (L Body). Looks good. Did not leak a drop. $5
Shifter from Cavalier. I believe this came off a 92. $5
Grand Prix Passenger Side Taillight. Needs a cleaning otherwise good condition. This should physically fit any 1988-96 Grand Prix. However, please look closely as the taillights had different bulb and pattern configurations. $20
T5 Shifter. I believe this came from a 93 Mustang. $5
I believe I also have a very good condition Lower Intake Manifold for a Gen II 3.1L in the basement somewhere. If anyone is interested let me know and I will see about locating it.
SOLD! 7730 ECM, this is the non-weather proof kind. Pulled from running 1990 Chevy Beretta L Body (includes mounting brackets/nuts). No chip/memcal. $15
SOLD! Gen II 3.1L Plenum. I have 2. Only 1 is pictured. They are identical other than the brake booster hose fitting. One is straight and the other has a 90* $5 each.
SOLD! Set of: Gen II 3.1L Fuel Rail + 6 Injectors + FPR. $10
SOLD! Gen II 3.1L Injector Harness. Includes harness for all 6 injectors. Not Pictured. $5
SOLD! Gen II 3.1L Valve Covers. Includes used rubber gaskets that can likely be reused. $5
