Dex-VI is a semi-synthetic blend so it should be fine.
Supposedly, the Dex-6 is backward compatible with Dex 3; meaning that you can add/mix the 6 with 3 but it's not recommended to add 3 to a transmission that has 6 in it
its designed to be backward compatible with DEX III
DEXRON-VI is generally Gp III although the spec does not preclude the use of PAO/Ester base combinations. The confusion arises because in the USA group III stocks can be labelled as synthetic.
Yes DEXRON-VI was designed to be backward compatable so it can be used in all Hydramatic transmisions that called for DEXRON-III or earlier DEXRON specifications. Try not to mix DEXRON-III with DEXRON-VI, only because if you do that you are in fact diluting the DEXRON-VI fluid with a less stable product and therefore throwing away much of the advantage. All you need to remember is that DEXRON-VI is far superior to DEXRON-III and also that DEXRON-III no longer 'exists' in terms of licensing so there's no control over the formulations (if you go out and buy a 'DEXRON-III' fluid in reality you have no idea what you're paying for!). In contrast, GM controls the formulations for DEXRON-VI licensed products ... so you know exactly what you're buying.
