ive got a few things for sale. first is a set of 00 3400 heads that are ported. they were gasket matched, ported and have bowl work. comes with ls6 springs installed. i sandblasted them clean, then hot tanked them at work (still a little paint and carbon though). the valves were also blasted and cleaned up. 220 shipped for the heads.
next item i have a 00 LIM that was also blasted and tanked clean (still has some small spots of paint that was thick). has one bolt hole broken but all i did was put a bolt up through the bottom and it sealed fine for me (ran 12psi through it). this was also ported and gasket matched. comes with a 180 degree thermostat installed. 65 shipped.
i have a 1990 Quad 4 282 with a swapped v6 bellhousing for sale. it has a lower 2nd,4th and 5th gear which is a noticable difference over the v6 trans. the trans is in perfect working/shifting condition with 67k on it. comes with the stock diff installed (also comes with a stock mounting bracket, its pictured with a modded one for the turbo downpipe) i removed the team green lsd to install in my other trans. 320 + shipping or pick up!
