Cylinder Heads 3.1 TBI
  • Wanted Cylinder Heads 3.1 TBI
    By Carfax stand this:
    VIN 1GNCU06D8LT11****
    Year/Make/Model: 1990 CHEVROLET LUMINA
    Body Style: SPORTS VAN
    Engine Type: 3.1L V6 MPI OHV 12V
    Manufactured In: UNITED STATES
    Search Results: 1 record found in our database
    I need for this Engine Cylinder Heads....
    Best regards McLin.
    Are they iron heads? If so lots of 2.8/3.1/3.4 RWD heads would fit (all same)
      I found this on:
      Rebuild
      FWD, APV, Transport, block #653, 519, crank #981, cast iron heads, with distributor.
      Best regards McLin.
        I was going to say that a set of heads would be easy to find in a junkyard but I see that you are in Germany. But check out Ebay, there is usually a few heads for sale on there.
        00 Grand Prix GTP Daytona
          I have a set that came off my 3.1 and were running strong (blew the bottom end from turbocharging).
          I'll let you have them for a reasonable price, but shipping would be expensive.
            I knew you would have a set:P
              Actually have a couple, but the other set is no better than boat anchors, lol.
                I need to flow the iron head with and without the complete manifold setup someday.
                enough of the off topic though:P what would it cost to ship a set of heads to germany? I dunno what they weigh.
                  A complete iron head top end weighs 84lbs IIRC, then you can subtract about 14lbs for the manifolds.
                  I Could send you a head and manifolds if you want (the junk ones will work), but I already have flow numbers for stock and SuperSix porting - thanks to turboproject...
                    Shipping will be about 150.00 IIRC. lbs + size of those heads just adds up.
                      I can get a head local probably but could use manifolds. Nice to see those numbers are close to mine. 3.4 DOHC pwns on the bench.
                        Probably because some of them ARE your numbers
                          oh. well then nevermind:P I like comparing off the same bench cause each setup is different. I use a tube for the exhaust and if you don't, those iron head 3.4 numbers look realistic for gen 2 for the most part.
                            IIRC, he is coming over to the states in a month or so, so he could pick them up and take them back on the plane with him.
                              ^ Don't you mean Weba is?
