Titlle says it all..... Make me an offer. The engine came out of a 95 Lumina, and has been gone through (thanks to my broken cam). Will include full engine, exhaust to throttle body. The intake is off, so you will need a new LIM gasket (which you proabbly want to make sure is new anyhow). The engine now has a new cam in it, and otherwise is perfect. I always used Mobil1, and the bearings and other wear areas (cylinders) are perect. 135psi+ on all cylinders. I went with a 3.4 DOHC to replace it.....go figure
I'm near Chicago, and best and first offer takes it.
