Items For Sale.
Prices include shipping by post office in the US.
First unconditional "I'll take it" reply gets first dibs.
I take paypal both credit card and non-credit card funded.
or money order but it will have to clear firs before I ship.
1) SOLD!!! ALDL Cable SOLD!!!!
I built this to scan my car. I made two to justify the cost of ordering a few parts. It will work with all OBDI cars including the 94-95 un-tuneable "OBD1.5" which I have definition files for to read and clear codes, as well as to read sensor data for both TunerPro RT and ScannerPro. If anyone needs those let me know I will post my latest ones up which are the most complete anywhere.
It is based off of the max232 chip so it outputs the correct standard output signals/voltages so it will be 100% compatible with all serial ports. It is powered internally by a 9v battery, delivering clean power and leaving your cigarette port open to power your laptop, and no stealing power from the serial port which means it will always function correctly. It has a power on/off switch, with a Blue LED to indicate power, and a Red-Orange LED that blinks when activity is received from the car. (this actually is helpful for cars that need a "disable coms" command to go through before connecting, as you can verify it was successful then connect). Plus it looks cool.
It will be 100% compatible with all serial ports due to internal regulated power and the correct rs232 standard output from the chip.
Circuit: (partially completed pic)
The finished product:
Comes with brand new Rayovac 9v installed. Blue/silver wire goes to ground. Copper wire goes to data port on ALDL on the car. It takes a lot of hours to solder up all this and fit it all in this small of a box. I don't want to do this again so this is the only one for sale. Sorry, won't be making more.
$45 shipped
2) Green 194 LED wedge bulbs
These are inverted cone and emit light to the sides and some in the front. I also have a few holders for using them in gauge clusters, if you want those they are 25cents extra each, limited qty. You can make green gauge back lighting or throw them in your courtesy lights under the dash, etc.
$1.00 each, +.50 shipping.
Min order 2.
6 available right now.
After you claim it, I will PM you with my paypal address.
Thanks!
$45 shipped
Min order 2.
Thanks!
