I need 2 pistons and connecting rods on them.. i pressed used rods on mine and they are on backwards and dont wanna risk breaking piston trying to turn the rods over.... its a pita.... lmk thanks
3100 Pistons & Connecting Rod
Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
Drilled/Slotted Rotors
White
3" Magnaflow Catback
90 Pontiac Turbo Grand Prix
5 Speed Swapped
127,000
Spec Stage 3 Clutch
230,000 mile Getrag 282
Emissions Deleted
Brand new Engine 1,000 Miles
Fully Custom Built carTags: None
Originally posted by 94GPGTP View PostI need 2 pistons and connecting rods on them.. i pressed used rods on mine and they are on backwards and dont wanna risk breaking piston trying to turn the rods over.... its a pita.... lmk thanks
Originally posted by ForcedFirebird View PostWhat did you use to press them on? Proper tooling should be able to turn them around without damage. A machine shop might charge you like $10/ea.Robert
New Rebuilt 3100
New Rebuilt 4T60-E
Exhaust
White
5 Speed Swapped
127,000
Spec Stage 3 Clutch
Emissions Deleted
Originally posted by TDIXON View Postput them in the oven for 10 to 20 min and the pins may come back out easier. idk but just a thought.
Cooling the pins or heating the rods make a faster press-on, but pressing off makes it difficlut since the metals are touching and transfer heat.
