96 GP SE Parts
  • 96 GP SE Parts
    Anyone need any parts from a 96 GP SE???
    its OBD-2
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    If it is a 2 door i'll take the front bumper. Does it have a leather back seat?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
      yes it is a 2 door.. It does not have leather..If it did i would have it in my car..
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        Any cracks in the front bumper? Do you have any pics?
        And where are you located at?
          i believe there is one small crack by the foglight but it is not all the way through... i can get you pics today... im in the chicagoland area south of the city... beecher,il
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
            Ya. Take a pic. The body shop will probably charge like 2 hours or so to fix it i think plus paint of course.
              Here are the pics of the Bumper... you can see the crack on the driversside foglight area.. its cracked but not all the way through.. over all the bumper is in good shape... with a good stripping of paint and good prep it will look good on your car..
              LMK Thanks
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
                how much u want?
                  what are you thinking its worth?
                  Robert
                  New Rebuilt 3100
                  New Rebuilt 4T60-E
                  Exhaust
                  White
                  5 Speed Swapped
                  127,000
                  Spec Stage 3 Clutch
                  Emissions Deleted
                    To be honest, with the damage, it has to be repaired and repainted. So that is $300+ for repairs. I had a damaged one a few years ago and I gave it away. I should of kept it.
                    But I'd do like $20 plus full shipping.
                      Wiring Harness
                      I need a 1996 Wiring Harness for my 1995 GTP. I'm doing an ECM upgrade to a 1996 with OBDII. Do you know if this wiring harness for the 3.1 is the same as the 3.4L DOHC?
                      Thanks,
                      Jeff
                        Thanks,
                        Jeff
                        I would say no.. but put up a post and ask around.. hope this helps you out..
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                          I need three lug nut caps (long silver ones) and the hazard light switch on top of the steering column and the rear floor mats if they're nice and graphite.
                            i have the black caps on this car.. do you need the black piece that you push to turn the hazards on? and i believe the floor mats arnt stock.. i think they are cheap walmart ones..
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            White
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            Emissions Deleted
                              Dam...i guess I'll have to hit up a j-y...
