Anything you see you want...Everything for sale. Send me a PM and a fair price and we can go from there
-Z-Spec Racing / Vortech Supercharger Kit
-Vortech Charger Unit bearings upgraded from ABEC 5 to ABEC 9
-Stage 2 pully kit installed capable of 15 psi
-Forged Arias Racing Pistons with a Compression of 9.1
-Light Weight chromoly Performance PushRods
-MilzyMotorSports Stage 1 Boost cam
-Comp Cams 26986 Valve Springs rated at 122 lb @ 1.750 and 283 lb @ 1.175, Coil Bind 1.040
-Delphi 28 Lb/Hr Fuel injectors
-NGK TR-7 IX Iridium Spark Plugs
-Custom 3.5” Cold Air Intake
-RSM Racing Poly/Aluminum Tranny/Motor Mount
-B&M Tranny Cooler
-RSM Racing 62mm Throttle Body
-Ported & Polished Upper Intake Manifold
Powder Coated Red w/ Polished 3400SFI Lettering
-Polished Fuel Rail
-Valve Cover – Powder Coated Red
-RK Sport Carbon Fiber Coolant Tank Cover
-MAP Engineering Throttle Body Heat Shield (useless but I have it :P)
-Taylor 8mm Spark Plug Wires & Boots
-Casper Electronics Manual Hi-Speed Fan Switch
-The Other Guys Ceramic Coated Headers
-Random Technology 3” Down pipe Fabricated to Match Headers
-Hi-Flow Cat
-Borla Cat-Back Exhaust
-High Volume Oil Pump
-HP tuners Software with a Dyno tune from Method MotorWorks Fresno
-B&M Tranny Cooler
-Polished Fuel Rail
-Hi-Flow Cat
