Shop Heater
- I bought this used in the spring, and never hooked it up. I had documentation from the guy who I bought it from saying it was just serviced, but I have since lost that paper. Its made by trane, I believe the model number is GPNC004AAA100000 (it's was a little difficult to read, so I hope thats right). It outputs 36000 btu, so it should be suffice for anyones garage shop. The measurements are 14 1/8 wide, 25 3/4 high, 19 3/8 long, and is designed to hang from your ceiling. It uses 110v and requires a natural gas source. I've decided to go a different route with heating my garage so this is up for grabs. 250$ obo
Car Stuff
- Used Garrett turbo. This thing seems big. The cold side is .60 a/r, and the inlet size is 2 1/8" big. It's oiled cooled. External wastegate. I used to have more info about this, but can't seem to find any of it. If memory serves me right, it's a t40b. $200 obo
- Used Garret T25 turbocharger from a 99 Saab. The turbo only has 35 000 miles on it. It spins freely with no shaft play. The turbo is water and oiled cooled. The a/r on the intake side is .48, exhaust side .49. It is internally wastegated. On the plunger for the wastegate, their is a very small dent (shown in the pic). As far as I understand it, this will not affect it's performance in anyway. The turbo still has the name plate on it, showing the model number (452068-1), and that it's made in italy. $100 obo
- First Gen DSM blowoff valve with flange. $40
- Sunbird Cluster with speedo that goes up to 200km. It also has the stock boost gauge in the tach. I ran this in my 91 sunbird, and just had the o2 hooked up to the boost gauge. 40$ obo
- Stock sunbird cd player. It's ran for me, but every once in a while it would have problems reading the cd. The cd was fairly scratched though, so this could have been the cause. Usually I could unplug the power to it to reset it, and it would then read the cd again. $25obo
- Knuckles off of a 92 sunbird. I would replace the wheel bearings cause there fucked. Does not come with abs sensors. $40 obo
- Front/Rear sway bars off of a 92 sunbird gt. 25$ for the pair.
- Gen II 3.1 mpfi stock throttle bodies. They will include the TPS, I have 2 of them. $25 each obo.
- Gen II 3.1 mpfi stock exhaust manifolds. It comes with the crossover pipe. $25 obo for all 3.
- Gen II 3.1 mpfi stock upper intake manifold. $15
- Gen II 3.1 mpfi stock lower intake manifold. $15
- Gen II 3.1 mpfi stock valve covers $15
- Gen II 3.1 mpfi stock fuel rail. This came out of an engine I never ran (as it was seized). I can only assume it works. I would give the user a couple of weeks to test it, and if it doesn't work, refund his/her money. $15 obo
- Gen III 3.1 mpfi stock upper intake manifold. It's the small port one. I started polishing it, but then I switched to a different intake, and never finished polishing it. Pics tells the story. $20 obo
- Small intercooler off of a renault something or rather. It's measurements are 7.25in wide by 8.25in tall by 3.5in thick. Both inlets are on one side. End caps are plastic. Overall length is about 13in. $50 obo
- Gen II 3.1 mpfi stock timing chain cover. $20 obo
- Gen II 3.1 mpfi heads. I have a couple of sets I think. They are probably cracked tho, but should be fairly complete. If anyone is interested in these, I can get more info. 20$ for the pair.
Shoot me an offer on anything. I also have other shit lying around for 3.1's, or some left over stuff from my 92 sunbird, so if you need something, just ask, I may have it.
Thanks
feavs
Car Stuff
Thanks
feavs
