1996 chevy Corsica/Baltimore MD
  • 1996 chevy Corsica/Baltimore MD
    1996 chevy Corsica with 96400 miles on the clock with a 3.1 V6 auto trans
    The car is in overall good condtion with good tires good brakes thight front end no major leaks drive belt is ok I just repalced the intake gasket a week ago including chaning the oil three times.
    The car runs good but sometimes has a long crank time ? on fisrt start not sure on this the car will need a Left CV boot and an sway bar link on the left front other than that I could not find much else wrong than that (less than $60?)
    The body dose have some small dings and scrtaches in the paint but looks ok at a glance the only major ( I call it minor) is the pass side mirror is missing an chip out of the edge of the housing . The glass is good all the way around no chips or cracks.
    All the lights work inside and out the wipers work on all speeds all the power windows work from the master switch and at the doors the power locks work. The AM/FM cd player (aftermarket) works .Fresh battery No warning lights no check engine light.
    If you would like more pics just ask or if you would like to see the car just drop me an line so we can set up a time.
    Paul
    Car is outside of Baltimore MD 21220
