I have a used APEXI Neo for sale $300+ $20S&H if outside Edmonton.
I am running it on my Grand Prix GTP. I noticed big changes once I figured out how to tune the incoming air.
But I am moving away from the performance game. I am now getting into stereo gear.
I can take a few pics and video of the item if you want. But it looks mint.
This is good for some people that may not want to get into a stand alone computer system for what ever reasons.
I installed this on my car in 1.5 hours and that was taking my time. I have all the instructions on how to install and use.
Here is the info on it from APEXI.
Features include:
- Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
CONCEPT:
High resolution fuel control with integrated VTEC control.
CHARACTERISTICS:
Revolutionary color FED display easily customized by the user. *Not compatible with i-VTEC for controlling i-VTEC (can still be used as a fuel controller)*
Features include:
- Compact design
- Color FED display
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
CONCEPT:
CHARACTERISTICS:
