93 Z34 Engine and 94 Gtp Engine both 3.4
  • 93 Z34 Engine and 94 Gtp Engine both 3.4
    have 2 3.4 dohc for sale. the z34 engine is good comes with block,pan,heads,cams,valve covers,lower intake, and engine wiring harness. this engine came out of a 5 speed car comes with 5 speed flywheel.
    Gtp engine is good for crank,rods,pistons,pan,heads,and cams. the block is cracked.
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    Would you seperate the flywheel and if so how much?
      $60 shipped let me know thanks
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        how much for the lower intake
          how about 35 shipped?
          Robert
          New Rebuilt 3100
          New Rebuilt 4T60-E
          Exhaust
          White
          5 Speed Swapped
          127,000
          Spec Stage 3 Clutch
          Emissions Deleted
            and how about the upper intake too also do u have any performance parts
              no on both, sorry!
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
                ok how much for the valve covers and the lower intake then
                  ok how much for the valve covers and the lower intake then i will be getting the lower intake so i also need so payment method
