What I have now:
2" outlet on turbo into 45* bend, to 90* bend, to 90* bend, to 2.25" IC.
2.25" IC to 2" pipe to 90* bend, to 90* bend, to 45*, to 45* to 3" TB.
What I notice is that I have quite a bit of throttle lag (not turbo lag). I can snap the throttle and its just real sluggish to respond which I know is due to the 2" press bent tubing. I am re-doing it all which is what I need help with. I'm keeping the Saab 900 IC cause it seems to be doing a decent job, after some spirited driving in 30* weather I open the hood and feel the plenum and its cold
So for the piping, what would be best? 2" - 2.25" right out of the turbo to all 2.25" piping to the TB. Or should I go with 2.25" to the IC and use 2.5" or 3" from the IC to the plenum to increase the volume of air before the TB?
