I'm not too sure on the T70, you can always calculate it... lets see... a 3.4l... say 6500 RPM... 5lbs: intercooled
Lbs/Min Peak 35.13358433
Pressure Ratio 1.340136054
The T70 will spool, but what a waste... It'll start spooling somewhere around 3500 to 3750.
8lbs intercooled
Lbs/Min Peak 40.48387636
Pressure Ratio 1.544217687
It'll spool somewhere around 3250 peak boost about 5250-5500 RPM.. then it'll fall off.
14.7 lbs intercooled
Lbs/Min Peak 52.43286189
Pressure Ratio 2
It'll spool about 3500 RPM, and peak about 5500... lots of room for that 9000 RPM redline... LOL
I would look at the T68-1 over the T70... for low boost
5lbs intercooled:
1750 - 2000 RPM spool, Peak efficentcy 4000 RPM, then it'll drop off, but still be producting boost through the redline.
8lbs intercooled:
2500 RPM spool, Peak at 4500 RPM, then it'll drop off, but still produces boost thru redline.
14.7lbs intercooled:
3500-4000 RPM spool, peak at about 5000 RPM, then drop off fast to redline.
Hope this helps...
8lbs intercooled
Pressure Ratio 2
5lbs intercooled:
8lbs intercooled:
Hope this helps...
