Im back
  • Im back
    Alright guys, I am back.. I have my LQ1 sittin on the stand, ready to be torn into, built, blown, and 6 speed'd..
    I am shoppin for the Turbo right now, and I WANT a GT35r.. Tough to come across, yes.. However, I have been lookin at this one:
    Garrett T3 ar .42 on the cool side and a .48 on the hot..
    ..I want to make certain this blower will spool up strapped to a DOHC before slappin 9k on the tach.. I also can get a smokin deal on one as well..
    ..As far as the rest of the car, it is torn apart, and the old tired 3.1 needs to be dropped.. I am droppin the whole crade as I need to swap out the steering rack, engine cradle, suspension, etc.. I cant WAIT to have my Turbo Lumina that can run with my buddy's Camaro! Thanks in advance for any advice!
    90 Chevy Lumina: 3.1L V6; swapping out for TLQ1
    94 Cutty Supreme: 3100 V6
    Soon: Something new?
    Sounds small. I'd bet it would spool before 1500 rpm... Turbos with a/r ratios in that range tend to be pretty tiny. Two of them might work though...
    The smallest T3 turbine I would go with is a stage 3 in a 0.63 a/r housing. A stage V in a 0.82 housing would be more like it and the P-trim T4 would let you take advantage of more power than you know what to do with. If you find anything that's a T3/T4 hybrid with a stage 3 or stage V turbine, it should work very well for you. The A/R ratios are swappable, but you would need a new turbine housing for each one. They can help you configure your powerband and lag.
    Good T3/T4 hybrids are easy to find, but most are designed for D16's and other ridiculously small Honda motors- not a 3+ liter V6 motor.
    Tim
    325 whp 350 lb-ft
      Tim, thanks! You are so knowledgable, it is amazing! I was just lookin at this blower, and I figured it would spool before 9k like I want, but 1500 is too soon :P..
      ..I am lookin to go with a single setup now, so I'll look for a T3 as you mentioned..
        FYI- on the compressor side do nothing smaller than a 60 trim T04E. The 60-1 and 67mm T04R wheels are good and quite a bit larger.
        Tim
        325 whp 350 lb-ft
          What of a T70? A friend of mine swears the DOHC can spool it with no problem with its smallest trim and a/r..
          And Syn was sellin this one, and I am gonna see about pickin it up:
          model # t04b90
          compressor a/r .60
          turbine a/r .96
            Get a holset, they're cheap and good performers. I've got an HX40, but an HX35 is probally a bit more reasonable for spool time and power output.
            26+6=1
              What trim is the one Syn is selling? Some of the T04B compressors (like versions of the 60-1) are very good and some are less than optimal.
              A T70 might work well on an auto with a high stall, but it probably would be a bit laggy from a roll. (honestly- anything with a T4 turbine housing will be a bit laggy from a roll/stop- bigger 3" catless exhaust makes a huge difference here)
              Tim
              325 whp 350 lb-ft
                Very good turbos. The Honda-Tech forced induction forum has a great writeup on Holset turbos. (some of their sponsors also have regular T3/T4's or T4's going for under $600)
                Tim
                325 whp 350 lb-ft
                  my HX40 was 50 bux, a rebuild kit is 60 bux, and a you can get a better exhaust side from bullseye for under 200... Guess which way I'm going
                  26+6=1
                    Sorry been so long guys to reply.. Been on the hunt for Turbos, so I forgot my thread here.. Whoopsie..
                    ..Anyway, I thought the same a t70 would be too laggy on my car, especially as I am installing a manual transmission, so it wouldn't perform how I would want.. Here is the info on the one Syn was sellin.. I dont know if he still is or not, as I cant get a hold of him.. Syn, if you are reading this, I want it!
                    model # t04b90
                    compressor a/r .60
                    turbine a/r .96
                    That's all I have on it.. THat's all he sent to me.. Damn I hope he can sell it.. Let me know man.. I want it bad!
                    EDIT: Can anyone tell me real fast if they know of any good places to have forged internals for the DOHC made? I dont want to have everything crap itself out when I am drivin it around town, lol.. What of Cams?
                      Update: (Figured I would do it this way instead of starting a new thread.. Waste of server space, lol)
                      Alright, I started tearin into my DOHC today, and have a lot of work to do.. (Needs new valves for one thing.. Look as though they've been over heated at some point and oil starved)
                      I am now searching for companies that specialize in forged pistons and beefier internals for this motor.. (I know I can give anyone specs, but I am also lookin for the best price I can get on these forged pieces..) I do wonder about the cams.. I imagine there is nothing wrong with the stock cams, as far as power gains and will stick to them..
                      ..Computer tunig is where I am a total noob.. In my other thread in "DOHC general" I explained I will be going to OBD2 with this car.. And I am wanting to hae a computer built into the car to monitor the OBD2 system.. What do I have to do as far as "tuning" my ECM/PCM? How do I reprog. the thing.. These are a few trick I need to learn to do.. Because I know the stock controls wont be good for me.. Especially since i am going manual with this car..
                      ..Which brings me to another query: When I hit that clutch, which part of the turbo system will retain the spool when I go to shift to the next gear? It is the wastegate, is it not? Or does the BOV fall into that somehow? I knew what it was a long time ago, but have since forgotten..
                      ..I have my turbo selected, and am 90% sure I want to go with a T04E 60 trim turbo.. .63 AR an the 60 trim (Der..).. And a 3" catless, mandrel bent dual outlet exhaust (Thanks tim! ) I just thought I would share where I am at this point.. COmments are welcome!
                        Sounds good.
                        DHP and HP tuners have tuning software out for the 97+ Z34 PCM. DHP for sure does the 96 also.
                        For forged pistons, Ross racing may have some off the shelf ones that work. They do a lot of 60 degree V6 work.
                        The BOV is what helps keep the turbo spooled between shifts.
                        Tim
                        325 whp 350 lb-ft
                          Thats what I thought.. Thanks Tim! Now, assuming I had the thing bored over (The safe amount, lol) I know then I could find some for the correct sizing.. I am not sure about the wiring as i haven't gotten to tear into that monte yet (THe cutty decided to stop running) but can the 97 PCM plug directly into the 96 wiring harness? Thanks a ton!
                            You're welcome. The 97 computer can physically plug directly into the 96 wiring harness, but the pinouts are different and it will not work. The 97 PCM is designed to run a 4T65E and has extra inputs/outputs. The 96 PCM is still setup for the 4T60E.
                            Tim
                            325 whp 350 lb-ft
                              I see.. I wonder if this Monte is a 97 then.. Becuae when I pulled the tranny off it and sold that, the pan said "4t65e" on it.. I am not mistaken, because i thought I was going to need to use that tranny in my 94 supreme and I wasn't sure if it would work.. I'll need to go look into that!
