The 3400 rail with the 3500 plenum and any modifications, close-ups of the rail if possible so that I'll have an idea of what approach I'm going to take.
By the 3500 injectors being so new it's not likely there is anything available anywhere close to my budget, some of the high performance Fords have the right plug style injector but again I believe they are the longer version from the pictures I saw on ebay and they will also run upwards of near $300 for a set in the 40 lb/hr range, where the early design injectors can be had at much less in the high flow range. I won an auction last night for a set of 36 lb'ers.
It is weird in a way regarding the compression issue with the aluminum vs. cast iron heads but hey it works in my favor so I'll take it. I'm also going to take advantage of oil cooling to further reduce the internal engine temperatures. I have run an oil temp gauge before on a turbocharged 2.8L and the oil temp ran in the 240 range at times so if my cooler can keep it around 180 that would work wonders for the overall temperature and anti knock benefits with the heads and block having what amounts to an internal and external cooling effect working simultaneously.
If only GM had installed oil squirters on all 6 cylinders the way they did in the 3900. I'm tempted to look into buying one more 3500 just to tear down and do that to as well as port the heads and install the 3800 valves in to take advantage of the steel crank and powder forged rods. The pistons in all of GMs blown engines according to the spec sheets on their site are CAST, icluding those found in the supercharged solstice, I think that says a lot about the durability when detonation is absent.
Back to the TGP ecm briefly, I believe it much wiser to use the TGP programming and tune up to the 3500 instead of tuning down with the 3800SC programming due to the aluminum heads calling for a considerably different timing map. Us Fiero swappers labor over the issue of tuning the 3.4L from the camaro properly but the major contribution to that being a task is installing an intake system on it designed for a smaller engine that it was still to small for as opposed to leaving the stock intake on the 3.4L which flowed better than that found on the 2.8 in the Fiero.
Taking that route would certainly yield better performance even if you used the stock 2.8s programming simply because you at least have matched injectors on the larger engine which flow more fuel eventhough they are being pulsed on for the same amount of time that the 2.8 injectors are. Of course that's my theoretical opinion.
Thanks, guys for all your help, I have a very good source for parts and intend to acquire a roller cam and send it to Crane about 120 miles away from me and see about a profile and regrind. I was quoted $50 on the profile which is small beans for the knowledge, but I want to get all I can get out of this motor and if they can modify the cam to breath at 7K I'll send them the money to do so, and I'll post what I find out for all to see.
I took a look at the LS6 springs but I don't know that the springs on the 3500 aren't strong enough to reach that high with say a .015-.030 shim. I would much rather do the shims than the springs if that is sufficient. If the engine weren't so new I'd be more eager to mix and match, but I have heard individuals make claims that were incorrect so I want to be sure before I switch parts out unnecessarily. I will not really get things going until next month, I'm supposed to be studying for a really big exam but can't quite suppress my plans until I'm done.
