3800 supercharger on a 3400
  • #16
    Originally posted by JubjubW View Post
    is it? my bad i just took what a guy said from my other forum
    It's one of roughly 18 kits made I know because I used to own one.
    • #17
      That doesn't look like a Magnuson kit. Sure, its mounted the same, but the components don't look like any Magnuson kit I've ever seen. I could be wrong...
      • #18
        howd it do? it doesnt look all that complex just a long shaft and how its mounted... but i cant see much from the picture
        • #19
          Their where two different versions of the kit IIRC the one pictured is one of 4 or 5 found mainly on concept cars. I beleive the only difference was the updated inlet/outlet casting.
          It's a pretty simple install and it works great when I had mine the only issue I had was keeping the tires from spinning
          • #20
            I'll have to find the pic I have of one of the concept cars (just happened to be one Hot Rod magazine's Power Tour about 2 years before the kit was released), and see how it compares.
            • #21
              I stand corrected...
              • #22
                how in gods name are u supposed to change the spark plugs. do u seriously have to pull the whole charger
                MODS: DS CAI, TCE 65 mm tb, TCE AFPR, TCE LS lifter springs, WOT ported UIM and LIM, 3500 heads, comp cams valve springs locks and retainers, 1393 grind cam, S&S headers, custom 2.5 in catback, flowmaster 80 series , no rez, and to top it all off, an MPR tune. Among misc gauges and appearence things
                • #23
                  Out of curiosity what concept car is that? Do you have any more pictures? I don't recall ever seeing that color scheme before.
                  If I remember right I could still reach my hand around the drive shaft and get the plugs out.
                  • #24
                    Here you go. Like I said, it was on Power Tour ~2 yrs before the kit came out. Not sure if it was a Magnuson test mule or what...
                    • #25
                      I'll post some new pics and videos of my 3.4 /m90. Blow through propane carb/ intercooled. I love it!
                      • #26
                        what car did you have the m90 on? fiero or f-body i can understand. but if you say grand am, WOW!
                        would love to see the pics anyway, no matter what it was on. Thanks.
                        • #27
                          He has a older S10 with an f-body 3.4 running on propane with the m90. He has videos of his setup posted elsewhere.
                          1995 Grand Am SE
