Does anyone know if there are any books that tell you anything about supercharging with a carb??? I have a 85 blazer with a 3.4 and i bought a eaton m90 supercharger(having to fab a manifold though). If anyone knows of any books that I could look at to get this done thanks...
Supercharging with a carb???
RE: Supercharging with a carb???
Considering supercharging started off with carbs, there are probably a million books out there on the subject. Superchargers have been around forever, so just go to a library and go from there...-Brad-
Check with Holley, Barry Grant, and Predator. They have a line of custom supercharger carbs. There are some other companies out there that make them as well but these will be your best bet. It also make a difference if the carb is positive boost or negative boost(before or after the supercharger) but the eaton is a manifold style so yours would be a negative boost application.
There is also the fuel injection option on the supercharger. I am going to use that when I rebuild the 383 in my truck and add a B&M to it.95 Beretta Z-26
