Best Nitrious Kit for a 3100?
  • Best Nitrious Kit for a 3100?
    well i'm doing the hybrid swap. and i'm looking for a good nitrious kit...
    i was looking at this kit on ebay.
    its a NOS wet kit. what do you think? or whats the best setup for my car?
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    You have a 95 with a 3100. How are you doing a hybrid swap? Hybrids are 3x00 top ends on 3.1s...
      That price is high. Better deals on ebay....or better yet....goto a store! oooh aaah!
      1984 Indy Fiero 3.4L
      13.7 sec @ 98 mph
      *ALL THROTTLE AND NO BOTTLE*
        From what I can tell, that exact same kit is on Summit for $349. Hmm.. ebay for $469, or Summit for $349.
        Contrary to popular belief, you don't always get the best deals on eBay, especially for new stuff!!
          i got the universal nitrous works kit from summit. took over a second off my 1/8th time so im not complaining.
            i'm doing the hybrid swap. with the better valvetrain
              2000+ 3100 intakes P&P. 3400 P&P heads. 62mm TB. with a cam. if thats what you mean by "how are you doing your hybrid swap."
                That's not a hybrid swap.
                  whatever what is a hybrid swap. and what is the swap i'm doing called? u could of told me. now i feel dumb.
                    A hybrid swap is taking a Gen II 3.1, and using the topend from a Gen III 660 (3X00). It provides a MUCH larger gain then what you are doing. You're just using an updated version of the same topend. The only thing better about the "valvetrain" is the rocker arms, and the slightly bigger intake valves. You could've just put 1.6 rocker arms on your 3100 for the same effect. That and the 00+ 3100 intakes and you would have virtually the same gain. It doesn't seem worth it to change the heads to me.
                    This is a hybrid swap:
                    Shawn
                    99 Grand Prix GT
                      i thought someone told me that i need the heads? and that its much better to have the new aluminum heads.
                      thanks for clearing that up for me shawn.
                        they likely figured you had a gen 2 motor. in your case its a head swap.
