turbo 1998 monte carlo
  • turbo 1998 monte carlo
    had a brainsyorm today want to turbo my 1998 monte carlo. i have a turbo from a 1990 toyota supra laying around and i know that i can mount it but i was wondering what this would do to the computer and sensors? and do i need bigger injectors and can the mass air sensor be in line with boost going through it ? how much boost can i run (6-8 psi) where do i get extra fuel? would an apex-i piggyback fuel comp work i am trying to do all this 4 under 250. any help would be greatly app. thanks
    first of all what motor is in ur car, and secondly, it shouldn't be that hard, i believe you're on the right track because someone has successfully done it that way using a GM mini-AFC, i wouldn't try going over 6psi or so. and you'll need a dyno to tune it.
    93 Z34 Auto (old, dead, slow, in peices)
    91 GTP 5spd (older, faster, better)
      3100 engine I assume? Being OBD2 I'm not sure how well the PCM will handle it, its picky about those sorts of things.
        I'm not sure that a Toyota CT-26 turbo is exactly the best thing to attach to a 3100.... I heard that they are fairly limited..
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          thanks 4 the help turbo is on and goeing it ran a 15.2 in the quarter not to bad. with the addition of an intercooler if i am lucky and on a cold day it might hit 14.9 boost is set at 6.5 psi all i really needed was a pressure regulator air fuel is where it should be
            You are kidding right
            3800 S3 intercooled turbo...
              Pics.
                WTF, that was fast
                1995 Monte Carlo LS
                3400 SFI 60v6
                  13 days later and he has a turbo....
                    Oh I C...I think he meant he had the turbo in the car...(like passenger seat or something) and then went to the track...
                      the CT-26 stock will do about 350hp.
                        A N/A 3100 W-Body running a 15.2 would be a miracle of god.
                          just about. baby jesus might have a hand in that as well.
                            Do they have different versions of the CT-26? (maybe i'm thinking of the one from the 3S-GTE).. i heard they were not the best in producing the boost..
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            Cliff Scott
                            89 BerettaGT
                            04 AleroGX
                              3100 > DOHC, and we all know it.
