About the piping. Run the charge pipe fromt he back turbo over the timing belt on the passenger side. The firewall will need to be pressed in about an inch to fit a 2.5" pipe through the space between the back corner of the UIM and the firewall. Then it goes beside the radiator into a dual chamber air to air intercooler. And the front turbo would be easy, but you would need to move or do somehting with the fans.
As for the ports, the 1st gen exhaust manifolds are oversized by a minimum of 1/16" all the way around, and the smae goes for NAPA gaskets. However the ports aren't the same on top and bottom, they are a bit more rounded on top. Hard to explain.
That weld looks sooooo much better than mine
![Wink](https://www.60degreev6.com/vb5/core/images/smilies/icon_wink.gif)
