LX9 front manifolds and boost
  • LX9 front manifolds and boost
    I've seen a few people using 2 of the front exhaust manifolds for turbo builds but only in RWD applications I believe, has anyone used them in a FWD setup? Debating on trying to build a crossover for my 03 Grand Am, have a 5spd swap as well so that frees up some space in the back
    would work good for a TT setup.. one off each manifold. but for a single it might not be the best option. I have 2 front manifolds for my LQ1 single turbo setup.. it faces both outlets to the drivers side and makes a "Y" pipe collect into the turbo.. (like stock TGP Setup). these manifolds face down so it would work well to hang a small turbo off each... thats about it.
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
      Not sure if I would have the space for a twin setup but either way these should flow better then log manifolds I think
        That front one on the back would be aweful close to hitting your rack, wouldn't it?
          shouldn't I don't think, not sure how familiar you are with my generation N-body but the rack mounts fairly low on the subframe
          shitty pic but should clear I think
            I think you are right. I think the older n body cars they mounted to the firewall, that's why I mentioned that.
              I kind of have a feeling it would still fit as this setup came out of a sunbird gt.. guessing they probably have similar rack setups
