how much boost does the 3.1 turbo get stock?
3.1 lg5 question
~7PSI
the Top Gun chip kicks it up to 10 PSI, lots of people run it that way. Not sure on power but 3 PSI typically would be 20-30 HP, results could be skewed by tons of other factors though.
If you have an LG5 probably one of the best/easiest upgrades would be a GT28 as the GT25 is way too small for that motor. GT28 is still probably too small but it should bolt to the stock y-pipe.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
If a turbo is too small it will choke the motor. A Gt30 might even be considered too small so think how small a GT25 is.. It's more like a 4-cylinder turbo and even then a lot of guys will upgrade from a stock GT25 to a GT28.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
It might spool instantly but then at higher rpm a small turbo will max out and will prevent you from making more power. Also if you try to run a lot of boost to compensate you will just end up creating a ton of heat in the intake.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
I'd still do it. Not a STI but sure makes it fun to drive. This turbo was desighed around the low rpm 3.1. So you don't need to rev the piss out of it. It make a mean torque motor.88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
