91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
Never broke a stock one, they take boost quite nicely. No custom lines required, ect.
That's true, stock FPRs will do the job. I am using a stock type now at over 10 psi.
There are still times when it's handy to have an adjustable regulator. For example, when the vacuum at idle is less than stock, like at higher altitude, or higher idle RPM is used, the base fuel pressure can change. Also, stock regulators vary for different years. The 1999 Alero V6 regulator runs at 35 psi, the 2003 at 45 psi. There was another 6 cyl GM FPR that looked identical to those but was rated even higher. Each used different rated injectors, and of course aftermarket injectors vary, too. If you ever need to change injectors in the course of optimizing the setup, that versatility is nice.
Also, the way the stock FPR and return line is positioned in certain engines tends to heat up the fuel going back to into the pump canister.
= Best track time: 12.951 @ 104.48, 1.839 60 ft. (Beech Bend Raceway Park, 11-23-13), 50 Deg. F http://www.youtube.com/watch?v=hpVYZPbpPzk
Ran stock regulators but that what the chip required and had the injector capacity. No problems what so ever. Even for a 20 year old regulator. Only regulator that sucked for me was my grand am regulator its a 2003 so it has a slightly higher pressure than the gen2 early gen3 but went through 2 where the diaphram leaked fuel into the vacuum hose. That was stock not boosted.
90 psi requires a name brand regulator like aeromotive. or maybe your looking at a FMU like the Vortec .
WellI need 90 PSI because the injectors are sided for 52 PSI. 90 PSI is worse case running more than 30 PSI of boost which I won't ever do. SO I guess I could get away with 75 to 85 PSI. I just was curious what everyone is running. It looks like I'll go with an aftermarket fuel pump module that electronically throttles the fuel pump. Thats what ZR1s, CTS-Vs and the new Camaro ZL1 do.
I ran stock FPR on my cars. when i went turbo before tune i used a Vortech FMU as well as the stock FPR. it would run a stock pressure at idle and with the FMU and a 12:1 disc it would increase pressure 12lbs for every 1lb of boost. they have different discs to give you different pressures like 10:1, 8:1, 6:1. this will be ideal. it will connect to the return line on your stock fuel system and feed pressure source from a vac line on the manifold.
Otherwise a aftermarket adjustable FPR will do what you want if you want to set it to a specific pressure all the time. Our cars have a return fuel system so it again goes in line with the stock fuel return line and is ajustable without removing anything... set screw or a bolt.
S
Shane "RedZMonte" 2004 Corvette Z06 Commemorative Edition-VIRGIN 1995 Monte Carlo Z34 14.38@101mph, 331hp/355tq
-Turbonetics T04E Super 60 Turbo, 2.5" Borla Catback, OBDII, 42.5# Injectors 2004 Subaru WRX STI -Lightly Modded (SOLD) 1994 Lumina Z34 -VIRGIN (SOLD) 1992 Lumina Z34-VIRGIN (RIP) 1992 L67 Lumina Z34 (SOLD) 1990 Turbo Grand Prix (SOLD)
With 30 psi boost, 90 psi fuel line shouldn't be a problem. The 30 psi boost will help open the plunger, reducing the probability of hydro locking them.
Making the injectors act as if they are spraying from 60psi fuel lines into atmospheric pressure.
I'm sure you knew that, just pointing it out in case.
btw, I use stock regulator as well up to 12psi no problems.
Which year/make do you recommend? I think mine finally failed by what the gauge is reading.
