what are you guys doing for your oil feed to the turbo? is the plugged port above the oil filter suitable for the feed? I was thinking I would unplug it, and just use a length of braided stainless. it looks like 3/8" NPT, is it?
Turbo oil line
Hmm I think it is 1/4" NPT; I'm using a braided line off the plugged port by the oil filter for feed; I installed my oil pressure sending unit in the stock 3500 location.
I went with -3 braided stainless because that's what was recommended for my turbo. Some say they need either -3 or -4 with a restrictor in it. Best to find out which size is recommended for your turbo.'89 Firebird, 3500 Turbo, T56, 9-bolt/4.11
'86 Fiero, 3500, 4-speed
Originally posted by bigcheese View Postits 1/8th npt"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Could use an oil filter sandwich adapter. No drill/tap needed. Just slip between filter and block and can route oil feed, oil sensors and some have return lines to fit an oil cooler.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
there's already a drilled and tapped port on the side of the block, if you look at the oil filter, it's at about 10-11 o'clock. I've ordered -4 for the feed, and -12 for the drain."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View Postthere's already a drilled and tapped port on the side of the block, if you look at the oil filter, it's at about 10-11 o'clock. I've ordered -4 for the feed, and -12 for the drain.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by bigcheese View Post3 weeks to go."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
