Randy post the link to you build let him check it out
3400 turbo.
Originally posted by unchained01 View PostRandy post the link to you build let him check it out
"Living is doing everything you want to do and dying is everything else"
There's nothing wrong with VG turbos. Porsche uses two of them on a few of their cars. What matters is matching characteristics to your engine. There is a reason they are on both Porsche and diesel trucks. Unfortunately the Porsche ones are quite pricey on eBay.
Originally posted by NateD4 View PostThere's nothing wrong with VG turbos. Porsche uses two of them on a few of their cars. What matters is matching characteristics to your engine. There is a reason they are on both Porsche and diesel trucks. Unfortunately the Porsche ones are quite pricey on eBay.
Diesel vg turbos were not made for that.
I also already stated that the Porsche does use a VG turbo for the 996 but at about $5k a pop, and you needing two of them, who is going to buy those just to claim they have vgt?
Originally posted by bigcheese View PostYou didn't read my post, otherwise you would have seen that I said the diesel vg turbos aren't designed for the hotter exhaust gasses from a gasoline burning engine instead of the cooler exhaust from a diesel engine.
Lots of gas boosted engines run diesel turbos. It is all about the size of the inducer/exducer of the compressor/turbine. Match that to the engine and it will work, diesel or gas. Heat energy is heat energy regardless of the fuel used. The turbo utilizes heat energy to boost the engine.
But it is your car, just saying. You could get some great advise here.Last edited by TGP37; 03-28-2013, 12:39 PM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by NateD4 View PostIs that a hint of sarcasm I detect?1999 GLS MP90 supercharged / 2003 GL MP62 supercharged / 2004 GLS stock
I've never known diesel exhaust temps to be any less than gas exhaust temps, especially when pushed.
It doesn't matter anyway, the original topic at hand will prove that the turbo is a bad idea, and not work like the OP expects it to, but you know, those of us that actually have turbocharged cars don't know better.
Yeah I'm not sure how Holset turbos compare... But considering everyone seems to size turbos on A/R ratio and the VGTs have variable areas that approach full close (giving A/R probably down to .3 or less)... And about 400 CFM of air @3500 RPM for 6.6L displacement I'd say the turbine side should be just fine. For reference a 3.4L at 6500 RPM uses 389 CFM.
Compressor side...
This is from a 94mm 48 trim compressor wheel (stock is 88 mm for an LLY). The 77% island happens at @55lbsm/min and a 3:1 pressure ratio.
That gives similar single point performance as a Garret GT35R @55lbsm/min and a 3:1 pressure ratio except at the 72% island and near the top of the boost graph.
Originally posted by AleroB888 View PostI did not see it as sarcasm. But I'm afraid to mention what I was considering for a turbo build. I have to find the right wording for the question, lol
Last edited by TGP37; 03-29-2013, 01:00 PM.1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by NateD4 View PostAs for earlier discussions... Diesel turbine housings are huge.... And packaging tough.
It sounds like the OP is on the right track with a properly sized turbo.....
Oh I was referring to the Duramax turbo packaging wise it is a chore. Rather than a traditional flange the header 2:1 style inlet GM cast onto these adds almost 2" in turbine section diameter. It physically won't fit in my car. I'm going to end up either cutting that inlet and making a new one or casting/gabbing a new housing to make it my way.
The size of the Duramax turbo vs your 6.5L makes sense. If I'm not mistaken the 'max turbo is about the same physical and flow size as a T68 or T70 sized turbo. Might flow a bit les but the duty and power range they are designed for is larger than a 6.5L original design.
In my case my target is a minimum of 350 HP max possible 700. I'll probably be 'very' happy with 450-500.
How does that 6.5L turbo work on a gas engine?
As far as the OP I think with a bit of know how he can get what he wants from it. No idea why he's concerned with late spool and sub 350 HP numbers.... Generally high HP and lag go together.
If I were him I'd focus on the resulting torque curve... Or build the thing with the cheapest t3/t4 hybrid I can find with a square t3 flange and see how it runs. Learn and refine with a better turbo. Then sell the old turbo on eBay.
I'm slightly fascinated by this post. I tend to 'think' most t3/t4 sized turbos put you in the 200 to 400 HP range. a/r helps dial the spool rpm and trim the peak power. My vote is put something on and go with it.
BTW there used to be a lot of Solstice-Sky/Cobalt SS turbos cheap on eBay.
I've seen dyno pulls to the 300-350 range from them. I originally looked at two of those to hit my 600 HP goal. But decided a single Duramax turbo was easier to plumb. To bad I didn't realize how large the housings are.....
If you don't recommend a turbo what should the OP put in?
