How far do you want your BOV away from MAF? (Obviously a post turbo MAF system) Also, post or pre intercooler best?
Blow Off Valve
I don't run a MAF, but I would assume a minimum of a foot, if possible because of the turbulence it could cause and throw off MAF readings. As far as before or after the intercooler, I would run I before. That way every bit of a cooled by it is used, not half of it vented and wasted and you use every bit of your intercooler efficiency.
Edit: and ninja'd
Sent from my HTC One X using Tapatalk 2-60v6's 2nd Jon M.
So is it 6 inches or 12+? :P 6 inches would be no problem, 12+ i'll just have to put it in my fender well.You may or may not know 10 times what i do.
I would guess from what I've been reading it's a minimum of 6 inches on each side of it so air has a chance to settle down and give a more accurate reading. That's why the honeycomb is in there, to help smooth flow.
Originally posted by pocket-rocket View PostI would guess from what I've been reading it's a minimum of 6 inches on each side of it so air has a chance to settle down and give a more accurate reading. That's why the honeycomb is in there, to help smooth flow.
Sent from my HTC One X using Tapatalk 2You may or may not know 10 times what i do.
Here's mine. I'm not sure how far it is, but it works well. I had it after the MAF for a while. The fireballs were cool, but the noise and occasional stalling that resulted weren't... This is a MUCH better way to go.
Some BOVs are integrated into the turbo, others are right next to the throttle body. There are benefits of each. I would try to put it at least 6" away from the MAF sensor and before the MAF sensor. Other than that, put it wherever it fits.
Tim
325 whp 350 lb-ft
never mind... Didn't realize this was a blow through maf setup...
You have one choice.. Pre maf or deal with metered air being discharged and the richness of that.Last edited by 3400-95-Modified; 08-20-2012, 09:55 AM.
Thanks for the input everyone. I would prefer to run a pre turbo MAF, but for now I'm running a post. I moved the MAF a little more than 6 inches from the TB (But it should be ok). The BOV is 12ish inches away from the MAF and is tucked in the wheel well. It's a very tight fit in the wheel well since the air filter, and both charge pipes are in there. But everything fit after some trimming. The car runs great and everything is working, except my wastegate opens at 10 psi instead of 6.. But the BoV seems to be doing its job!You may or may not know 10 times what i do.
No issues here. Blow Threw MAF and BOV is 1.5-2ft from TB
Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
Almost exactly like mine, just the head of mine faces the engine. Do you drive it in the winter at all? And is your ET at Bandimere?You may or may not know 10 times what i do.
