its a new sensation that is sweeping through... i was just wondering if anyone had any experience with twin charging. example. a turbo that feeds a roots/screw type supercharger. i'm currently saving for a desperatly needed rebuild and am wondering if this may be an option. i know with going this direction ungodly amounts of power can be made. example https://www.youtube.com/watch?v=HmscSzFurwg . of course this guy has loads of money and is running the super/turbo chargers differently but its basically the same idea
Twin Charging
That has to be the coolest thing I've seen in a while, thanks for sharing
If someone here were to do it, you would most likely want to be rwd with a T56 and a solid rear axle, otherwise transmissions are going to get expensive. Although the progressiveness of the power mentioned would help the components live a bit longer than a strong and sudden shock load.
Sent from my Sony Tablet S using Tapatalk 2-60v6's 2nd Jon M.
it's just not that practical for our motors, nobody makes a roots/whipple/twinscrew for them, and the added costs don't support the gains IMO."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
why wont a roots/screw charger fit on our motors? i've been told they wont fit but never why they will not fit... theres also quite a few benifits to going this route too. you dont have to have the turbo produce insane amounts of boost. about 10 psi will do depending on the amount of boost the supercharger is making but if its 10 and 10 ( supercharger psi, and another 10 from the turbo) you end up producing much closer to 24 psi of boost instead of 20 so neither charger has to be overworked to produce large amounts of boost. i've been reading up and have found a few great articles about this subject. http://www.eng-tips.com/viewthread.cfm?qid=174690 this ones a great read if you've got some time. explains some of the basics.Last edited by Big_Jeff; 06-11-2012, 03:25 AM.
Originally posted by Big_Jeff View Postwhy wont a roots/screw charger fit on our motors? i've been told they wont fit but never why they will not fit... theres also quite a few benifits to going this route too. you dont have to have the turbo produce insane amounts of boost. about 10 psi will do depending on the amount of boost the supercharger is making but if its 10 and 10 ( supercharger psi, and another 10 from the turbo) you end up producing much closer to 24 psi of boost instead of 20 so neither charger has to be overworked to produce large amounts of boost. i've been reading up and have found a few great articles about this subject. http://www.eng-tips.com/viewthread.cfm?qid=174690 this ones a great read if you've got some time. explains some of the basics."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
it's been done, but I have yet to see it done well, I wouldn't do it with iron heads, why bother? your heads are where you make power period. yes you can put boost to them, but boost on 3x00 heads makes a good thing better. I would flip the supercharger so the outlet points up, and then modify the upper intake to redirect the air back down into the engine, similar to how it's done on a Zr1 vette. but again, it's alot of work for not alot of gain...."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
I wouldn't do it. It's been done before (quite a few of the GTP turbo guys started this way), but is very complex, expensive, heavy, and performance is lacking. You have to worry about intercooling both systems and finding room for both. The MP90 is great at creating hot air, but not much else. Modern turbos can have very good power throughout your RPM range. They won't have the same low end as a positive displacement supercharger, but think of it as traction control. If you are thinking about a roots type supercharger, the TVS series is MUCH more efficient than the older MP range.
325 whp 350 lb-ft
Originally posted by timg View PostI wouldn't do it. It's been done before (quite a few of the GTP turbo guys started this way), but is very complex, expensive, heavy, and performance is lacking. You have to worry about intercooling both systems and finding room for both. The MP90 is great at creating hot air, but not much else. Modern turbos can have very good power throughout your RPM range. They won't have the same low end as a positive displacement supercharger, but think of it as traction control. If you are thinking about a roots type supercharger, the TVS series is MUCH more efficient than the older MP range.
Tim1999 GLS MP90 supercharged / 2003 GL MP62 supercharged / 2004 GLS stock
I think Shane's old Z34 Lumina with a L67 swap was pulling similar times at Bandimere. The L67's can be made quite fast (compared with stock) on the M90, but when it comes time to make big power, it's just not there. The TVS series seems to be much more efficient at making big numbers (I just saw a TVS2300 dyno video that was over 1000 hp and 900 ft-lbf).
325 whp 350 lb-ft
