I have a 95' obd2 swapped beretta 3400/3500 hybrid with 60k on the bottom end, with headers, ported/polished everything, and an upgraded 4t60e.
I would like to run this kit on 8-10psi (was told around 80-100hp) because i have stock engine internals except for SD headgaskets and metal lim gaskets
I would like to know what exactly i would need to do to an rsm 3x00 kit to make it work.
I was told i would need to modify the shaft length?
And was told i will need to make a bracket to mount one end to the trans?
Also what walbro fuel pump would i need as well as size injectors?
I basicly need to know everything and I am new to all of this and any info would help.
thanx!
thanx!
