cool man, I was impressed with how raising the ATF pressure made my 4t60e pull harder and shifts had more grab-n-go.
New injectors and a better pump, yeah, that'll do it all right. A cap full of top-end cleaner per tank full of gas does well to counter act the dry ethanol in the fuel. And will help keep the new fueling system clean for years to come. i think BP already adds something similar to their fuel.
Do you have stock fuel lines still? I had to upgrade to a larger line, had very slight pressure loss at the top-end/high rpm range in boost. Putting in a 3/8" ID really helped that a lot.
My fuel pressure jumped from 45 ish psi to 65psi at idle after the line swap.
