SO that means I can just leave the wastegate vac line connected to the throttlebody vac port? Or should I move it by making a hole for it in between the tb and the maf? Also on the waste gate and bov there is only one vac port I need to worry
about right? cause both of them have a vac port pointing down, and my friends think there should be something there...
Also I hope everything is just because of a small mistake on the fuel rail now. The wideband has been reading 20 which was the max the gauge can handle, but when I step on the throttle it would go down to like 13-16 which is normal since it is eating more fuel right? SO as of now I have a super rich or a super lean problem? How so you get a lower reading? What readings are you guys getting?
