HUORRAY! me and my friends got the car running, we ran down to the gas station with no exhaust but a downpipe to get premium gas after a bottle of octane boost since it had reg gas in it, lol. the stalling was probably a mass amount of problems causing it to stall the way it did. We changed the tps and adjusted the throttle bracket screw somewhat. and tighten all the vac lines with hoses, and put a checkvalve in the fpr(since it ran better with it?????) But it stalls when the turbo spools, I think and the pedal is dam dam touchy. I think I need a check valve on the map sensor too as told by schmieder, probably cause my pcm won't read it.... Well after work tomorrow night hopefully we can start the exhaust for real, cause we think it will run better with a exhaust as of now
THough a problem is that the brake booster ain't working? or I should say it feels as though the brake pedal won't move too. That means I should get a check valve for it since I thought it had one already? The line to the brake boost was about 1/2" I think. so guess I will have to look around?
